Most makes of grab adhesive have both a Solvented or Solvent-Free version?
When and why should I used each of them……
  • Is a "grab adhesive" the same thing as a contact adhesive? – keshlam Mar 26 '16 at 14:19
  • @keshlam, no it is like "no more nails" – Walker Mar 26 '16 at 16:18
  • OK. Hadn't heard the term before. – keshlam Mar 26 '16 at 16:23
It depends on just 2 things. What you're doing & what the labeling says. I use Loctite Power Grab for most of my situations & I haven't had a single issue yet, but I've only just gotten to 10-years on stuff where I first used it.
Liquid Nails though I don't use ever. Because, I found it in multiple situations & renovations where it was barely 10-years old & up to 30-years old & the entire range was always dried out & completely released from everything, worthless.
Solvent-Free adhesives would really just be used for low VOC situations or upholstery, fabric, foam & foam-board applications, where you don't want to damage what's being glued.
  • To be fair, the formula for Liquid Nails is probably very different than it was 10 or 30 years ago. – isherwood Apr 26 '16 at 19:39
