I have 2x8 joists over an 8 foot span that were eaten by termites on one end. I need to repair all of the joists in a small room. The building is double wythe structural brick that is approximately 100 years old. My current plan is to cut the affected ends of the joists off, attach a ledger board to the brick face using sleeve anchors, then use joist hangers to put in new ends and sister the old joists and new joists together. Does this sound like a good plan? How deep do the sleeve anchors need to be in? How much should the old and new joist overlap and what is the best way to secure them together?
  • I'm not sure I'd trust sleeve anchors in brick. Concrete, maybe. Where I've seen face-mount joists in modern construction a Simpson Strong-Tie system was used to embed subhangers in the poured walls, and special overlay hangers were then used with fasteners going through the joists and into the subhangers. There was no fastener or anchor drilled into the concrete.
    Feb 24, 2016 at 22:02
  • Like so: youtube.com/watch?v=fVntvXMS7zk
    Feb 24, 2016 at 22:07
Presuming this is the area from How two install hardwood floors in a long room with a subfloor that has a plane change in the middle? It really should be rot from being unprotected against the moist brick, which looks the same as termite damage...unless you found dead or live termites of course. Future instances can be avoided with just a Zip-lock type freezer bag over the beam's end.
But, No on the anchor idea, just not strong nor uniform enough. And No, on the iLikeDirt idea, it separates the floor from the structure. If you can't just shim them & leave sleeping dogs lie. Then, get a carpenter to get their thoughts on threat level of leaving them & what's proper &/or legal in your area for a repair.
Now, if you're lucky see if you have slots instead of pockets, this you can work with to get new beams in. Meaning, can you see the full pocket & a subfloor gap or does the subfloor seem to go into the brick? Lucky
If no, then one very successful (& proper & legal around me) method is to put or leave full depth scabs in the pockets. PocketScabs
And, those get end-lagged into & through your new ledger, which is actually a whole new floor frame. ScabConnect
Just to kind of give you another view of the practice of framing in a new floor structure with old &/or new lumber. It looks something like this with the scabs being on the backside of the ledger or the light wood (it's a bad & wrong picture, but the best basic visual I could find). NewFrame
You would supplement the lags with upside down joist hangers on top of the scabs, since lags don't have the full shear resistance of a 2x8. Again, just for your visual understanding if the carpenter starts explaining what he'd do & it happens to sound like this. Or, see what he thinks of this, him falling down laughing would be explanation enough.
The benefits of the above method is that nothing changes, the pockets keep doing what they've done, the structure remains braced, no damage is done to any brick in trying to coax new beams in that may be too long & outwardly stress the structure & the new ledgers & joists can be custom heighted. But, hopefully the carpenter's just fine with leaving them in.
Your approach does not seem safe or sane. Since this is a structural problem, if I were you, I would consult a structural engineer and not make a DIY job out of it. Consequences for doing this sort of job incorrectly include the collapse of the building and potential death of yourself or anyone else in it or in the vicinity.
The general approach for this sort of thing is to fasten a new load-bearing wall or column to the joist and chop off the rotten part at the brick face with a chainsaw. Needless to say, the details are heavily dependent on site conditions.
TL;DR: Install new joists without removing the old ones, fastened the exact same way the old ones are : No ledger board and no sleeve anchors. Pocketed into the brick.
You make new pockets for sisters, and you keep the sisters as large as possible while still being able to squeeze them in there. If you have a center beam to support the other side, insert the sister in sideways and then 'flip it up' with a 5 pound sledge and a block of wood. Then tap it into the pocket from the other end.
If the other end is going to be joist-hung, cut a slight angle* on it, so that once one end is inserted into the pocket, the other will slide right into place.
Then use 1\4" structural wood screws to attach the sisters to the existing joists and then mortar what's left of the pocket (with the appropriate material), having removed as much lose debris as possible.
*An angle so slight, you might get away with just easing the top edge by whacking it with a hammer. Then pound that sucker home, once it's in there at all. Just make sure it would fit in that space in the first place, and that the angle (of insertion) is what's giving you trouble. You might also need to do something similar for the 'flip it up' end, which is easily shimmed once in place, so no worries.
P.S. - Fix your roof, do some tuck pointing and check your gutters. You either have water infiltration or drainage issues (you need a better sump). If this is below grade, you might want to look at having your foundation sealed (on the outside! $$$).
