I understand that ”flush mount“ lighting means the fixture hugs the ceiling.
What does "semi-flush mount" lighting mean?
Sign up to join this communityI understand that ”flush mount“ lighting means the fixture hugs the ceiling.
It's like a short chandelier as shown in your example. The "semi" can range from the shade being just a couple of inches away from the ceiling to usually no more than 12" away. Bugs love them.
Actually, flush mount means the fixture is in the ceiling--flush means "on the same plane as". Otherwise it's surface mount. (Marketing departments use the term to sound clever when they should say "surface mount".)
Examples of flush mounting are recessed cannisters and undercabinet lighting.
So, "semi-flush mount" would mean partially recessed. Examples would be eyeball-style recessed cans and channel track lighting.
