I am replacing some framing and sheet rock that has been contaminated by mice. The basement has cinder block walls that come up about half way for some reason. The house was built in the 1950s.
In some of the basement the top of the wall is sealed with cement, but in this case the cement has been removed in order to install the studs and sheet rock.
What should be done to this open block wall before replacing the studs and sheet rock?
