What is the best way to fill a pothole in asphalt?
There are some huge potholes in an alley used by 5 homes that I would like to repair - meaning it gets a fair bit of traffic each day.
Would gravel be a sustainable filler into the holes?
Does it have to be more asphalt?
Cold patch asphalt repair can be packed into holes and stands up well for standard car/truck use. If the hole is really deep you can pack crushed rock to fill the hole and save some $. I would not use pea gravel to fill the deeper holes as it never locks together like crushed rock. After filling and adding the patch material I like to run over it with my truck to pack it then if needed add a little more until the patch is even with the original level.
  • Better to overfill the hole set a strip of 3/4 plywood over the patch and than run it over a few times. Add more. Leaving it higher as it will eventually become more compact as it is driven over.
    – ojait
    Feb 22, 2016 at 1:02
