So I live in a rented apartment and some things did not go as planned and ended up with a puppy before moving instead of after. Anyways I just noticed he has been chewing on the frame inside my bedroom and I'm just wondering how to fix this so I can obtain as much of my deposit as possible
    A picture would really help here. – Daniel Griscom Feb 20 '16 at 12:48
    Which part of the frame is damaged? Is only the casing damaged, or is the jamb damaged as well? Photos will help. – Tester101 Feb 20 '16 at 15:12
  • Wood filler is probably the answer, but a picture would help a lot. – Aloysius Defenestrate Feb 20 '16 at 15:37
  • See the linked post and its answers, and if your situation is different, please add details to your question to explain how. Thanks and welcome to the site! – Niall C. Feb 20 '16 at 18:29
-2
Spray it with a very light water solution of cayenne pepper after perfectly sculpting & restoring the frame to new condition with wood putty & sanding & priming & painting accordingly. Get the pup more or some chew toys & approved rawhide bones to address the teething issues...one's that hold treats will make the pup forget about the door frame.
