I bought a big box vanity with sink etc already attached. It was 1/4" off from being flush at the back so I decided to reseat it. Knifed and sawed the thing off then scraped the silicone off the sink/counter top.
Problem is, the wood sides are particle board and I can't get the silicone off. Nor can I cut or sand it without ruining the base. The majority of the lumpy caulk was on the sink side, so the remaining caulk on the base is fairly flat.
Is there anything I can use to simply reattach the vanity top with this residue silicone?
