The wire is too short for me, and I want to extend it...
I'm thinking that the audio quality will lessen if I connect a different wire.
I don't know as well if where will I get or what wire will I use
Sign up to join this communityThe wire is too short for me, and I want to extend it...
You can twist together a string of coat hangers and I'd bet you wouldn't notice the sound quality difference.
After 5 tests, none could determine which was the Monster 1000 cable or the coat hanger wire. Further, when music was played through the coat hanger wire, we were asked if what we heard sounded good to us. All agreed that what was heard sounded excellent, however, when A-B tests occurred, it was impossible to determine which sounded best the majority of the time and which wire was in use.
Solder, crimp, or twist on a length of wire equal to or larger than the existing wire and be happy.
