I'm trying to remove a bathtub diverter spigot, but I can't tell whether it is a screw-on or a slip-on (with a hex bolt at the bottom). My spigot has the notch where a hex bolt would normally be, but when I look inside the notch, I can't see anything but a metal plate, a plastic tab, and some white silicone. Does this mean that I have a screw-on or do I have to remove something to get to the hex bolt inside the notch? I can turn the spigot some with my hand, but I think the silicone is resisting the torque. I don't want to just start wrenching away without some better information.
Any idea on how to remove this type of spigot? Thanks!
faucet
  • Is there a cap screw in the outlet end? – Ed Beal Feb 18 '16 at 23:17
you have to slide the white plastic tab towards the mouth of the spigot. its essentially like a quick fit pneumatic fitting. its a spring loaded compression fitting. sliding the plastic tab forward against the spring pressure releases the seal and lets you slide the spigot off of the wallpipe. you can twist a little to make it easier and lubricate with dishsoap to get it to move.
| improve this answer | |
  • Thanks for the answer. I'm going to give it a try and report back. – user3111891 Feb 19 '16 at 18:02
