I have a light on a pair of 3 way switches. I want to add 5 recessed cans to that circuit. It is currently set up with power at the light fixture and 14/3 wires ran from the fixture to both switches. Can I tie the other fixtures into this setup using 14/2 and running my wires parallel? If not, what would be a suggested way of doing it?
Yes. You'll connect the wires feeding to the next fixture, to the wires that feed the current light fixture.
Basically, you'll start with this...
basic 3-way wiring
Then you'll add the additional lights like this...
Additional light fixtures
NOTES:
  • I've excluded the grounding conductors to simplify the diagram, make sure you properly ground all the fixtures.
  • The black wire coming from the "3-way wiring" bubble, might actually be white, red, or some other color.
| improve this answer | |
