Can I run 12-2 NM-B wire from my 20 amp dedicated breaker under my house and then using a four by four box splice 12-2 UF wire to run underground to my water pump house?
Running the wire would be in a dry crawl space, and the 4 x 4 box that the splice will be will also be in the dry crawl space mounted to a floor beam.
