I just finished tiling the shower surround around my tub. I knew that the tub wasn't level when I started but it became more evident toward the end of tiling.
On one end of the tub, there is 1/8" gap between my tub and the tile. On the other end of the tub that gap expands to around 1/4" or more. I checked my tile and it's level all the way around—it's just my tub isn't.
I plan on caulking this gap but are there any special considerations for a gap that large?
Thank you
  • Often, folks will start tiling at the ceiling or at some arbitrary level and work downward, then cut tiles to fit against the tub. Is that not the case here?
    Commented Feb 15, 2016 at 16:46
  • I started from the tub and worked up. This was my first shower surround tiling project. It turned out well but now I know why I should pick an arbitrary point and work down!
    – user2687
    Commented Feb 15, 2016 at 17:00
No, except that you need a product that doesn't shrink much (or you need to pre-fill to minimize depth and shrinkage). Pure silicone is good, as is urethane (though urethane is very difficult to work with if you're inexperienced--it sticks to everything, including fingers, and stays stuck).
1/4" isn't unmanageable. Cut your tube at an angle, then trim the very tip flat:
 _
Apply the caulk with the cut parallel to the wall, and try to avoid any additional tooling.
Some use a strategy of not caulking that gap at all, to avoid trapping water, rather letting it drain.
