I had three regular wall switches which operate appliances in this order:
1 Ceiling can lights (replaced with z-wave dimmer switch).
2 Fan lighting
3 Fan on/off (replaced with z-wave fan controller)
At the gang box, there are two incoming (line) wire sets from the breaker and three outbound (load) wire sets. All 5 of the neutrals (white) were twisted and capped. Switch one had two wires connected at the line terminal (one from the breaker and the other jumpered to switch 2 (line). Whats odd is that switch 2 had three wires connected to the line terminal (jumper from switch 1, the other line from the breaker, and another jumper to switch 3).
The two new switches (at position 1 and 3) require neutrals to be connected, so I jumpered each neutral terminal to the other 5 (7 total). Other than that, I kept the same config and things seems to work but I'd like some validation I did it correctly.
It seems redundant that switches 2 and 3 are powered of two lines. Would this cause my ceiling lights (operated by new dimmer switch) to get less current or would everything still draw exactly the current it needs regardless?
