As best I can tell, it's a 5" diameter, open-coat, all-metal (steel? tin?) arbor-mounted sanding disc.
It's the only thing that will remove tar from brick on my house, and I really need to purchase more. No idea where this one came from.
front
back
That looks exactly like a Porter Cable paint remover disk, at a glance. 24, 36 or 48 grit, $20 bucks or so.
Disc
The tool it's made for: the Porter-cable 7403 abrasive paint remover. There probably is a backing pad that supports the disc.
7403 paint remover
Here's the pad: Backing pad
Not affiliated, don't own one, do own some other Porter-Cable tools, happened to notice these discs when looking for some sanding supplies once.
| improve this answer | |
  • Seems like a match. So do the tabs in the arbor hole get pinched by the mounting bolt to retain the cover? – isherwood Feb 15 '16 at 3:13
  • I think the "tabs" are only tabs from lots of wear and tear - the surface on the "new" picture is a smooth cone, and that is clamped by a cone-washer. Could be it's merely similar, as I guess this is a 6" disk and the question does say 5"... – Ecnerwal Feb 15 '16 at 3:21
  • Thanks guys. Looks like a tungsten carbide disc is what I'm looking for. Mine is a 5" that looks like a thinner version of the Porter Cable. It was on a rubber backing plater for a drill. – Matthew Cook Feb 15 '16 at 3:29
That looks like a wrapper for something that had a solid inner component. You can probably find something with a more solid backing plate, like this one (example only), with tungsten or diamond granules.
