Got a 2 handle bathroom faucet that seems to be leaking. I think it is a Grohe Arden (I am not the original owner of the house and the faucet is over 10 yrs old). The only place I can see Grohe written is on the aerator. Anyway, I am trying to get the handle off and get to the O ring. How do I do that. I have attached an image of the faucet. A newbie to this kind of stuff.
faucet
[removed handle] [removed the nut. now, what to do?]3
The little dome shaped item on the top of the handle is a cover. You can carefully pry it off and there will be a screw in there. Remove the screw and the handle will come off.
  • Ok, did that got to image 3 where there is lockpin sitting on top a nut. Removed the lockpin, Tried to unscrew the nut. didn't make much progress. What should I do? What is the hex nut at the base for? Feb 13, 2016 at 19:24
