I couldn't find someone with the same problem so here goes:
I've replaced a ceiling fan (the old one had some parts missing), but as soon as I put the power back, the light and fan turn themselves on even when the light switch on the wall is off. Playing with the light switch (on and off and on and off) does nothing either. They respond when I pull their chains, though.
The new fan is a canarm Neptune 42" with no remote (product page: http://www.canarm.com/Residential/Ceiling_Fans/CeilingFans/42/CF42NEP4BN)
I have two wires coming out of the ceiling outlet: a black and a white I have four wires from the fan: green, white, black and blue
I shut off the power (breaker off) and then, as per instructions in the manual, I left the green (ground) by itself, connected the two white wires, connected the two black wires together then added the blue to the connection. As soon as I restored the power (aka put the breaker on), the light and fan were on and not responding to their switch on the wall.
I started googling and found a video where I was told to first connect the fan's black and blue wires together and then to connect them to the ceiling's black wire. Sadly, the problem remains as before.
I would gladly accept suggestions, thank you in advance for your help!
