Just got a Frigidaire gas range and the neighbor said when she used hers (same one) fire started because the packing material wasn't removed from the inside of the stove.
I opened stove's door, unscrewed two screws from the back and removedvthe bottom cover. The only thing I see is this insulation material. Is it insulation? Packaging material? Does it need to be removed?
