I hired a contractor to install 2 prehung fiberglass exterior doors in my home and I'm not sure if he measured incorrectly, but both doors have at least 1-1.25" of gap space on the sides between the frame & studs. Both doors also sit about 3/4" inch back, so the hinges are merely screwed into the door frame and won't even reach the stud without about 3" of length and some angling. The door jamb also sits a 1/2" behind the drywall, causing the molding to not lie flush with the door. One door is 30" with a 34" rough opening and the other is 36" with a 40" r.o.
I have 3 questions:
- Are both doors too small for my entryway?
- Does this pose some security risks of being easily kicked in?
- How can this be remedied? Order larger doors, add fillers between the gaps?
