I've tried every tool,wrench,chisel, hammer I've been told to use.what do I use to cut a sink strainer locknut off?
  • Can you post a photo of the stubborn locknut? – ThreePhaseEel Feb 3 '16 at 3:04
I've used mini (compact) hacksaws or multi saws, and a bit of patience.
An oscillating multitool might also do the job.
Carefully heating the nut with a torch, can sometimes loosen it up. Just make sure you've rinsed/wiped away any penetrating oil you've applied.
| improve this answer | |
You can also find a dedicated wrench designed specifically for sink drain nuts. https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=sink+basket+nut+wrench . I've also drilled perforations into the nut face and then tapped a old flathead screwdriver under the drill holes. The nut easily broke apart at the drilled metal openings.
