I have a beautiful post of reclaimed wood and I'd like to make it into a lamp. Not sure how to do this but I know the first step is to drill a hole all the way through it lengthwise. What is the tool and technique for this job and might I find a woodshop that could help me with it?
  • Probably a drill press, but that would work only if you have a bit long enough that won't deviate too much. How long and wide is the post? – Daniel Griscom Jan 24 '16 at 19:13
Long (18" and longer) drill bits do exist. If the hole is wide enough, bit extensions are also usable.
However, there's also a simple-but-elegant cheat. Cut the piece lengthwise, rout a channel in one or both sides, glue back together. If you make a thin-kerf cut, and are careful during reassembly, the glue line can be nearly invisible -- especially on straight-grained wood with the cut aligned with the grain lines.
| improve this answer | |
  • +1 When I read the question, splitting the post immediately came to mind, and, lo and behold, you answered it! – bib Jan 24 '16 at 20:47
  • For the kerf to be thin enough, would you have to use a band saw, or are there other options? Seems like even a thin-kerf table saw blade would be too much. – JPhi1618 Jan 25 '16 at 14:49
  • If you're cutting generally with the grain dividing and reassembling is surprisingly forgiving. – keshlam Jan 25 '16 at 14:53
  • My thoughts were somewhere between this and taking a notch out of the backside (towards wall) putting wires in the trough then covering with scrap wood to match. Since yours is a more likely method I'll upvote and just comment. – Dopeybob435 Jan 26 '16 at 15:59
Depends on the diameter and length. You may be able to use a conventional type bit and go half way from each end; I have made about 16" hole in 2" diameter that way . An expensive alternative is a gun drill (bit); it does not have spiral flutes and only cuts on one side of the point , and it can drill gun barrels. If the diameter is "large", a auger bit may do it, they make a pretty straight hole , but I never used on for this.
