Would someone give a good list of the equipment, tools, supplies, etc., I would need to take up carpet and padding that is glued to the concrete floor. Thank you.
    What are you intending to do after the carpet is off? The answer is likely going to be a lot different if you're replacing the carpet rather than, say, planning on staining the concrete. – Comintern Jan 23 '16 at 15:51
This has been answered previously several times. Here is the link: carpet glued down removal.
|improve this answer|||||
