This is very confusing to me.
The situation is like this... there's one light switch in the garage. This switch turns the light inside the garage on and also the lights on the outside of the garage. I want these to be separated so I can leave my outside garage lights on and the inside one off. I purchased a switch with two toggles that fit in the same single gang. It bridges the power side with a metal tab you can break off.
I was kind of thinking all the wires were ran back to the switch in the wall because there were so many wires. Is this possible to do?
Took all the wires apart to inspect. 3 Whites, 3 Blacks, a Red and a jumper black wire that goes from the switch to the other 3 Black wires.
This is what it looks like when wired and working.
Now I played around with possible wiring scenarios trying to figure out which wire went to which lamp. Then I crawled in the attack and looked where the outside lamps wires ran.
I found this. This is the back of the light bulb that is in the garage. 2 of the white wires are from the lamps outside, 1 goes to the garage door opener, and the black one goes back to where the wall with the switch is.
I guess first thing, has anyone seen this before or know what this is? Did someone sort of jerry rig this whole thing? Is it still possible to set up 2 switches and have the other two lights separated from the inside bulb? And if so, does anyone know how this could be done?
I'm guessing I can combine the two outside light wires together and run a separate wire down to the switch and fish it through the wall. Leaving the wiring how it is, and connect to one switch and the new wires to the other? Or is this wrong?
Thanks in advance for you help.
