The pressure gauge on our pump (which brings in water from our well) seems to be having troubles. The gauge is not supposed to go above 45. Usually, when the gauge reads 40 the pump will turn off.
Now, it is not causing the pump to turn off and will keep increasing pressure, according to the gauge. Does this seem to be a problem with the gauge, the pump, the regulation switch or the tank? I am not sure where to start.
Thank you.
