Why does my gas water heater have hot and cold water connections on the top of the tank and another set on the side of the tank?
    What model? So that we could look up the manual or pictures. – Dan D. Jan 18 '16 at 22:30
    Are the pipes on the side connected to a boiler? Could you include the make and model, and some photos? – Tester101 Jan 18 '16 at 23:34
1 set of connections for the sinks and one set for a water-based central heating system.
These systems are kept separated because the pipes and radiators used in such a central heating system is not meant for containing drinking water. (If you ever bled such a system you'd know from the smell alone)
-1
The second set should be for your heating, whether radiant or forced air.
