We live in flood plain area and we have a high water table. For some reason our home has a basement. We have lived there almost 15 years and our basement has flooded 3 times when it rains a lot. There is a hole for a sump pump, but the first time it rained and filled up we had like 2 feet of water for like 3 weeks, despite having 2 sump pumps going continuously. I guess it has to dry out enough outside and the water table has to go down before the water will stay out of the basement. I believe the water comes in through a few cracks in the floor and maybe the hole where the sump pump goes. The walls are cinder block and the ceiling is drywall. So what can be done to stop the water from coming in? Any advice is appreciated! Thanks!
I don't know if our home has foundation waterproofing. In 2005 when it really rained a lot for days on end is when we used 2 sump pumps and I think the reason they couldn't keep up is due to the water table being higher due to all the rain. So I think that even though we were pumping the water out of the basement, water kept coming through the floor because the water table was so high. Again, the times it has flooded, it has been a lot of water over 3 or 4 days so I wouldn't say it was moderate rain. We are at the bottom of a hill and there are 3 homes on the hill and the water comes off the hill onto our property. Even after it quits raining, water continues to come off the hill for a few days. Also, there is a pond across the street from us that they just dug down and hit water and there is a creek near us as well. Thanks for the advice.
add a comment
link under an answer if you want to discuss some detail with the respondent. Thanks, and welcome to the site!
