I can't find regulation 3.
Follow this trail from http://www.planningportal.gov.uk/buildingregulations/
Which leads you to The Building Regulations 2010, No. 2214, PART 2, Regulation 3
Meaning of building work
3.—(1) In these Regulations “building work” means—
(a) the erection or extension of a building;
(b) the provision or extension of a controlled service or fitting in
or in connection with a building;
(c) the material alteration of a building, or a controlled service or
fitting, as mentioned in paragraph (2);
(d) work required by regulation 6 (requirements relating to material
change of use);
(e) the insertion of insulating material into the cavity wall of a
building;
(f) work involving the underpinning of a building;
(g) work required by regulation 22 (requirements relating to a change
of energy status);
(h) work required by regulation 23 (requirements relating to thermal
elements);
(i) work required by regulation 28 (consequential improvements to
energy performance).
(2) An alteration is material for the purposes of these Regulations if
the work, or any part of it, would at any stage result—
(a) in a building or controlled service or fitting not complying with
a relevant requirement where previously it did; or
(b) in a building or controlled service or fitting which before the
work commenced did not comply with a relevant requirement, being
more unsatisfactory in relation to such a requirement.
(3) In paragraph (2) “relevant requirement” means any of the following
applicable requirements of Schedule 1, namely—
Part A (structure)
paragraph B1 (means of warning and escape)
paragraph B3 (internal fire spread—structure)
paragraph B4 (external fire spread)
paragraph B5 (access and facilities for the fire service)
Part M (access to and use of buildings).
