I need a mouse trap which sends a signal when it is activated, because in Finland, there is very strict animal legislation about catching mice. You cannot use glue traps. You can only use those mouse houses which the mouse can enter but not exit. However, the problem is that you have to look those traps regularly. The regular checking of the trap makes the cost of getting rid of mice on roofs expensive in Finland. The main problem is the cost of getting rid out of mice on the large surface of 400 m2. Other alternatives in preventing mice in roofs by
- Battery operated trail camera with bluetooth/cellular. Example: Primos, Browning, Bushnell, HC-300M, ... but should be with cellular or stable bluetooth where connection can be formed. Problem: current models are mostly with cellular and no bluetooth version.
- Activity cameras like GoPro Hero 3 only choice? Xiaomi Yi rejected because no Pebble support, in contrast to GoPro Hero 3.
- Eco Defense Ultrasonic Pest Repeller which may help in concentrating mice in one region. Link here. Too unstable and too inefficient if used alone.
Is there any mouse traps on the market which are battery operated and give signal when activated etc wifi, bluetooth?
