The manual on my kitchen cooktop states:
If a built-in wall oven is to be installed below this cooktop, the grounded outlet and gas supply piping must be located in an adjacent cabinet.
Is this a US code requirement? Or just a concession that there is no space for a gas hookup in the cabinet when a wall oven is installed in a base cabinet (since they go all the way back to the wall).
I want to move the gas line to inside the toe kick area of the cabinet with the oven and cooktop, as the 5" height there is more than enough space and is accessible when the oven is removed.
