My question is in relation to hot water reticulation. I want to supply hot water to 17 showers situated on the same floor. How do I go about it in terms of avoiding a drop in pressure when multi showers are in use. Are there any special valves I will need to install along the way?
closed as off-topic by Speedy Petey, ThreePhaseEel, Tester101 Jan 7 '16 at 13:08
  • This question does not appear to be about home improvement within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
  • 6
    This sounds like a commercial installation and might be a bit out of scope for the average 'Home Owner'. This sounds like a project where you might need to consult a commercial plumber that works on things like apartment complexes, gymnasium lockerrooms etc – BrownRedHawk Jan 6 '16 at 13:45
    I'm voting to close this question as off-topic because this isn't really DIY-sized. – ThreePhaseEel Jan 6 '16 at 23:24
This is a calculation which depends on supply pressure, flow required, and distance. To avoid unacceptable pressure drop is simply a matter of sizing all piping components properly. It is easy to design a system which minimizes pressure drop and there are numerous on-line calculators you can use: link to calculator.
Your bigger problem will be hot water supply. At 2.5 gpm (a conservative estimate for water-saving type shower head) you will use 42.5 gpm (assuming all showers are in use), a good portion of that will be hot water (ratio unknown as is dependent upon delivery temperature and mix temperature).
