What are these metal pieces attached to my basement poured concrete walls? They are about 2x2 with holes and were pressed into some kind of goop. These walls were poured in 1979. Can I remove them?
metal thing
12
Yes you can remove them. They are not a complete unit anymore. There was a wire extending from the center of the square disk, you will still see the nib that held the wire. The purpose of the wire was to push one type of insulation or another over it. The insulation was held in place by another disk that grabbed the wire and it would not allow the insulation to be pulled back off, at least not without some force to pull it through the disks.
Nowadays there are adhesives that will do the holding, and in some places, this type of retaining system is still used. For fiberglass batts or rolls is what would come to mind for using these.
  • @DavidRicherby I think it makes sense now - thanks for clarifying. I was confused because where is the insulation, then? I guess it was removed (or never installed after all)? – Roberto Jan 2 '16 at 23:52
    Correct on all counts, here is a link to a supplier of the perforated insulation supports as they are called. soundacousticsolutions.com/products/… – Jack Jan 3 '16 at 2:34
  • I added a picture to show how they are used – Jack Jan 3 '16 at 2:40
  • Ok. I assume there was insulation at one point that was removed. Thank you! I'll remove them or some of the protruding hardened glue so I can install foam flush with the wall. – Peter DeWeese Jan 3 '16 at 18:19
