I have a pantry door that has a dummy handle (a handle that looks like a normal door handle but is not connected to a latch). The door stays closed using a fairly shoddy catch like this one https://www.amazon.com/dp/B0042YFBBS/ref=cm_sw_r_cp_awd_l81HwbGC94ZJ9
I'd like the door to open and close like a normal door, but I don't want a handle on both sides of the door. Besides cutting a spot for the latch on the door, and the strike plate on the frame, do I need to buy a special door handle system for this? Or can I pull this off with a standard handle system somehow?
