For an indoor project that is likely to get bumped, knocked, etc. (e.g., door or window casing, cabinets, built-in bookshelves, etc.), should one expect that a good quality paint will resist chipping and peeling as about the same as a good quality stain sealed with a good quality polyurethane?
The specific circumstance we are evaluating is a kitchen island which has a cabinet base. The base is pine, and we're debating between either white paint, or white stain sealed with polyurethane.
However, it is highly probable that this item will be subject to a lot of bumps, knocks, and so forth. We're less concerned about the difference in appearance between the two finishes, and more interested in choosing the finish that will be the most durable, and the most resistant to chipping, peeling, and getting easily soiled.
