There appears to be moisture build up for a single window in a room. Cant tell if its inside or outside the insulation layer.
This is a double panel window (filled with argon gas).
  • I guess you can see it. We cannot however extend the internet through your eyes. – Michael Karas Dec 30 '15 at 18:45
  • It it's only a single window, then it's likely not condensation on the outside, but on the inside of the panes--which means you have a leaky seal. Need to replace the glass. – DA01 Dec 30 '15 at 19:54
    You can't touch the window to tell where the condensation is? – JPhi1618 Dec 30 '15 at 22:06
  • How to add images when usung a smart phone? – AlvinfromDiaspar Dec 31 '15 at 2:27
Condensation between the glass on multi-pane windows means the seal is compromised and the inert gas between the panes has escaped. So, yes... something is wrong.
