Having just moved into a house (from a flat) for the first time in my life), I am about to buy a corded drill. I would like to get something "universal", suitable for drilling the walls to hang a TV or get a cable through the wall into the garden, and also to drill in the laminate and wood. I have a screw driver that I'm using to assemble furniture and do some very simple drilling. But it was already not powerful enough to drill the laminate plate for the heating pipe, I had to borrow a proper drill.
With this in mind, I thought of buying a Metabo UHE 2450. It does just about everything I can think of. It's an SDS-plus hammer, so good for drilling walls and potential garden works. It also accepts both an SDS and a quick-release chucks, to hold all bit types (I have quite a few non-SDS drill bits already). It has two gears, for normal SDS operation and for faster drilling. So a perfect choice.
However, I've just realized it has a 50 mm diameter collar. I've never seen one before, the standard being 43 mm. I'd like to be able to use accessories, something like this drill stand. So I wonder: what can I use such collar for and is there anything like a 50 to 43 mm converter? Or is maybe the path I've chosen wrong for some other reason?
Update: I am in Europe, the walls are apparently from brick (at least outside, potentially concrete inside judging from the first pair of holes I had to make with the borrowed hammer drill, but I've never had brick walls before so I could be mistaken). Drilling concrete ceiling and floors is also a possibility.
