I'm practicing some connections on water lines, but I'm a bit worried the parts I have are bad.
nipple fully threaded
Here I finger tight the parts and then was able to do just a half turn with the channel lock before felling like it was "right". I'm not sure if that was enough or if I hit the "neck" of the male threads.
Below I show how the tape got after that, in the left side I used 15 turns of tape and on the right side just 5 turns. Both were cut around the last thread, does that indicate that the seal was done? How much tape is enough?
taped nipple
    The PTFE tape just has to seal around the circumference, it shouldn't matter if a small part of the threads cut the tape. In the past I've rarely used more than about 5 turns. The real test is to pressurize your connection and check for leaks. I much prefer compression fittings - much less messing around (other than to clean the pipe a little) Dec 30, 2015 at 12:47
  • I using PVC and CPVC so I just need to make those connection on 2 shower mixers, 10 connections total, and I never had good experiences with threaded connections Dec 30, 2015 at 13:09
    As per @Ecnerwal (whom I do trust) says these fittings do have a leak path. I'm not sure that PTFE tape is the 'right stuff' to seal this path. I think that some kind of dope or similar might ultimately do a better job that ptfe tape. Dec 30, 2015 at 14:15
  • The only dope I could find here is one based on solvents and some kind of rubber copolymer that semi hardens and is flexible after curing. I'm supposed to apply wait 3 minutes and join the connections. I couldn't find any with PTFE. Do you think this works? Dec 30, 2015 at 14:19
    That sounds like it might be the correct stuff. If they are tapered pipe threads, you would only need about 3 wraps with tape. If they are non-tapered threads, dope is the way to go. It hardens and prevents passage of materials through the threads. Dec 30, 2015 at 14:22
Luiz, to me this looks like it is not sealing and the pipe Dope liquid really doesn’t do much better than PFTE tape. I have had better luck staying with plastic 100% or metal 100% until the final fitting used to connect the shutoff valve. The PFTE tape should be “chewed up” when you put on the fitting, if not the 2 different sizes are not sealing and may very well leak. I have seen this same thing when folks use electrical couplings for pipe (they are not tapered like normal pipe couplings) and they started leaking after the walls were closed.
  • Those are metal to metal. The blue PVC pipe has female brass treads in it. Dec 30, 2015 at 14:56
  • They are only chewing one and a half turns, I don't think it is enough. I mentioned in a comment above a pipe dope that is solvent based and cures semi hard yet flexible. I think it should work better. Dec 30, 2015 at 14:59
  • I would be cautions it looks like the male is undersized or female is oversized or not tapered with the metal to metal they should much tighter.
    Dec 30, 2015 at 15:01
  • I don't have much choice, this is what is available here in Brazil? Dec 30, 2015 at 15:02
  • Metal to metal, you should get more than one turn's worth of tape cutting. Feb 28, 2016 at 16:47
