As part of some remodeling that I am doing, I am considering adding a switch to the wall switch box and a running 14/3 cable to the ceiling fan to control the fan and light (possible future addition) with separate switches.
I do not plan to add a light just yet (if ever).
I would terminate the hot wire inside the ceiling fan box with a wire nut. Is this safe practice? Or, should I only add the switch if I connect a light at the other end?
