After all water boiled, an empty teapot was left on the surface with turned on hob. You can see the spot on the photo. Is there some ways to fix or clean this?
Induction hob BOSCH PIB673F17E.
We use Bon Ami to clean our cooktop and it removes everything. But you can buy other products specifically designed not to scratch like Soft Scrub.
