My dryer won't turn. When I push the start button, I hear a hum. If I hold it down, it will hum for a moment and then stop with a click. I've checked the door switch and the belt, and tested for continuity on four thermal fuses/thermostats. Everything looks good. Is there a way to test if the motor itself has died?
Model: Kenmore 110 67904791
Thanks!
