I've used a drum sander and an edging sander to sand a floor. This has left the perimeter of the room a little different from the rest. What's the best way to blend both the regions ? I used 36,60,80 and 120 grits with the drum and a 60 grit on the edger.
  • You MUST use the same grits with the edger as the drum sander.
    – Jack
    Commented Dec 29, 2015 at 3:39
When re-finishing wood floors with drum and edge sanders one of the last steps is to blend the two areas with a floor machine sander. The floor machine is set-up for 100 and 120 grit sanding disks. Sanding this way between the two zones will even them out and blend in appearance.
