I was passing by a home, and noted that the garage flooring had a shiny vinyl coating, looking as if it were waterproof.
Does anyone know of this product used? And how long it lasts.
Sign up to join this communityI was passing by a home, and noted that the garage flooring had a shiny vinyl coating, looking as if it were waterproof.
I used the same type of epoxy paint for a basement floor:
Rust-oleum EPOXYSHIELD Garage Floor Coating
There are a lot of different versions as well as professionally applied products. If you want to do it yourself:
