Curious if anyone can tell what this is? Not sure if it's mold or if it is something else.
The yellow in the closeup is sap I believe but the black stuff almost looks like super small poppy seeds.
Attic Pic 01
Close Up of attic board
To my untrained eye, it does appear to be mold. The would indicate a moisture problem. The first place I would look is bathroom exhaust fan vents, they need to exhaust outside of the house, through the roof or out the siding, not into the attic space. Next I would check for ventilation, often in the form of soffit and ridge vents, but could also be gable vents. They need to be unobstructed. If neither of these appear to be the cause, then there could be a leak in the roof.
With any moisture sources solved, the typical remedy for the mold itself is a bleach solution, being careful to not get it on your skin, clothes, or anything else that could be damaged.
without a doubt that is mold, get a simple test kit from home depot to confirm but i've spent years in attic spaces, that my friend is black mold and is no joke. Dont use bleach, it doesn't kill all the spores, you've got to use a formulated mold killing solution like this one http://www.zoro.com/microban-disinfectant-spray-plus-size-1-gal-mint-221522000/i/G2564186/?gclid=CjwKEAiA18mzBRCo1e_-y_KLpXISJACEsANGmt9Scys6sptBznKbaWGqPJMFOi2iVK4s4CeuG3S6XhoCy5_w_wcB&gclsrc=aw.ds I'ts also important to try not to disturb the mold too much or the spores will travel. ventilate outside and spray the solution with at least a couple applications. when dried you can then work to remove the mold. Be sure to use all the proper safety procedures, you DO NOT want to ingest or breathe in the fumes from the spray or the spores from the mold. the mold is likely coming from a condensation buildup along your soffet, a good trick would be to get in there and attach cut foam blocks at the top of your wall cavity up to the roof deck to seal the soffet of from the attic space, wherever cooler and warmer air mix there will be condensation. something else you can do to help is get underneath the insulation and use 3m flashing tape to tape over partition walls, electrical wires, or any other protrusions through the ceiling plane. you'll save on heating costs by creating an envelope around your living space and cut down on the air mixing in your attic. good luck!
  • Okay, I'm working on getting a mold specialist to come and take a look. I'm not sure I could take care of it all considering it is on 95% of the attic. Though we don't have the traditional overhang soffit, I can see daylight at the edges where the roof meets the top of the wall. I call also feel a draft moving up the eaves. I thought this was a good thing(ventilation) but maybe it is causing the issue. – Zach Cross Dec 18 '15 at 1:10
  • Venting your attic is a good thing especially if you are not sure that your living space is sealed. Mold needs moisture, warmth and food to flourish. Unless you have severe moisture laden air with no openings to exhaust to the outside any fungi will not last very long. – ojait Dec 18 '15 at 1:47
    I'm going to strongly recommend against blocking the soffit vents, these have a lot of important uses including prevention of ice dams, cooling the attic in the hot summer, and removing moist air that gets into the attic from inside your home in the winter. – BMitch Dec 18 '15 at 3:35
  • Before I do anything, I want to have a mold expert take a look. – Zach Cross Dec 18 '15 at 3:45
I don't think that necessarily looks like mold, just the usual dark staining that can happen to wet wood, and is mostly harmless. In old houses you'll usually see some spots that are stained dark or black where there was a roof leak at some point in time, which was repaired, but the stain remains.
If the wood is soft - if it's easily imprinted when you push on it - it's probably rotten.
If the dark surface of the wood smudges, it could be mold.
Here's a pdf I just turned up with some more detailed info:
DISCOLORATIONS ON WOOD PRODUCTS: Causes and Implications - A Wood Protection Fact Sheet Forintek Canada
  • Interesting. Thanks for the PDF. It almost looks to me like it is the sapstain. But the tiny black dots can be wiped away so maybe I have some mold as well. – Zach Cross Dec 17 '15 at 21:40
It's difficult to tell based only on photos. The best course of action, is to get it tested.
