My sump pit has water leaking into it, coming through the plastic wall. I circled the portion that has water coming through it in the picture below. I just noticed it's pumping water every few minutes but this is after we had a lot of rain. Is that normal?
    It's hard to say if this is normal or not. Is the water constantly flowing and thus the pump is constantly on? Or is this happening after a rain storm? Water is supposed to flow into the sump hole and be pumped out - that's normal behavior. But if it never stops flowing and the pump is constantly running then maybe there is a broken water pipe somewhere?
    – ssaltman
    Commented Dec 16, 2015 at 20:11
  • I just noticed it after we had a lot of rain. I'm going to wait and see if it stops after a while.
    – Programmer
    Commented Dec 16, 2015 at 21:17
looks like you have a hole in your pit liner. but its doing its job its still removing water from under the foundation as it should. however i advise you to call a reputable drain inspection service to do a video inspection of the footing drain those are the two pipes you see entering the pit. if water is leaking into the pit from a hole in the plastic liner it should also be coming into it from the two pipes that enter the pit.
This is completely normal and doing what it's supposed to: collect and discharge the water under your house. I'd say my sump runs about once every 3~6 hours, regardless. And as much as every half an hour or more during a good rain.
Obviously if you suspect foul play you should call the professionals at 1-800 GHOSTBUSTERS.
