I need to take the door off of this to get access to the bolts to remove it and access the inside:
According to the installation instructions (found here), there is a cover in the center that is removed, then two pins pull out, allowing the box cover to be removed. Once removed, there are 4 bolts in the corners of the box holding the face plate on.
