I'm installing some line-level-dimmable LED undercabinet lighting in my kitchen. I'd like to protect it with one of the existing GFCI outlets in the area. My sequence would be GFCI > dimmer switch > LED lighting.
Are there any problems with this scenario? Would I be wiser to use a different device, such as a protected switch combo or a new home run from a GFCI breaker?
Note: I'm aware that it's a violation of code to control standard receptacles with dimmer switches. Assume that I'll use dedicated dimmable receptacles such as those provided by Lutron so we can avoid side discussion.
