An electrician friend of mine told me to get a Marley 2500 heater, and I was wondering if there's any specific order to connect wires to outside of no crossing color paths outside of the heater itself?
The manual can be found here: http://www.marleymep.com/en/assets/pdf/5200-2194-010.pdf
We're wiring the left side with a switch.
  • Try reading the brochure or installation stuff. – Andy aka Dec 13 '15 at 0:54
  • My dad, and I who are both software engineers have tried. – ajaxGuru Dec 13 '15 at 0:59
  • Your question is a bit unclear. I have answered what I think you are asking, let me know if I misunderstood. – HighInBC Dec 13 '15 at 1:28
    This belongs in Home Improvement. To the OP, please post links to model of thermostat and heater if possible. Pictures could also help. – mkeith Dec 13 '15 at 1:50
  • You're wiring this to a North American 240V/1ph circuit, right? – ThreePhaseEel Dec 13 '15 at 5:47
If your thermostat control is double-pole, then it doesn't really matter which switched wire gets connected to which heater wire. But if the thermostat is single-pole, then as HighInBC says, make sure it switches the hot wire.
With the single-pole, looking at figure 5 in the referenced manual, connect the switched hot to field wiring point L2, ie. the safety limit switch. Connect your neutral to field wiring point L1, ie. the heater element.
That way, when the heater eventually stops working because the thermostat has failed or the safety limit switch has opened, and you or your dad stabs the element with a screwdriver, you probably won't die.
| improve this answer | |
  • How do I know one of you will touch the element with a screwdriver? I have worked with software engineers all my life and I have never met one (yes, including me) who could refrain from doing this. – A. I. Breveleri Dec 13 '15 at 5:18
  • We didn't realize at first the circuit needs to be connected at both ends, so the wires can be exposed together. After that it worked just fine in the continuous loop. – i am me Dec 13 '15 at 16:20
I don't know what a Marley 2500 heater is but I am assuming it has a switch on it. There is a correct way. When wired correctly the switch will interrupt the hot wire, if wired backwards it will interrupt the neutral wire.
In base cases it will work, however if wired backwards then parts of the device will be hot when they are not supposed to be.
A classic example is a toaster. If wired correctly touching the elements should not shock you when the plunger is up. However if it is wired backwards the elements will be hot and if you are grounded you can get shocked.
  • FYI - in countries with decent regulatory requirements :-) - and anywhere sensible, toasters should have break switches in BOTH leda. All NZ ones do and I caused a productrecall after a nephew got a 230V shock because one break contact as trapped on in assembly in about 10% of the toasters. – Russell McMahon Dec 13 '15 at 11:41
