I have a 15 amp circuit that powers 8 recessed lights running 8 watt LED bulbs, a bathroom exhaust fan, a bathroom vanity light fixture and a wall outlet. In case this detail is important: the wall outlet is located in the room next to the bathroom and it is not a GFCI wall outlet.
When calculating the load on the circuit, what should I add for the wall outlet? Do I imagine a worst case scenario such as a vacuum cleaner, space heater or a clothing iron being plugged in? Or is there a generally-accepted load factor used for wall outlets? Thanks!
