I have a problematic pipe that has a blockage. Problematic for three reasons:
I could not snake through it (I have a 25 feet snake with a manual spin, spent a good while spinning trying to snake through, could not :(
it builds up blockage very quickly (2 months) - now can have only about 5% water in shower than usual to avoid flooding
no clean out cap/access point around the bendy area (red circle)
Can someone please suggest:
a) short term/quick fixes I can do?
b) solutions (expensive/inexpensive) that a plumber may be able to do?
Note that there's not much of a drop from shower drain level to the soil pipe level (because of the storage door and where soil pipe is located). See below.
Note also that the pipe is all glued up. Can't disconnect anywhere in order to take out the blockage.
Very many thanks for any comments/answers,
Ben
