Country: Canada
I was replacing my oven hood light fixtures with LED bulbs. One of the LED bulbs swapped in no problem. The other LED bulb was having trouble getting contact and subsequently a current. So I brute forced it a bit and out came the bulb with the thread assembly as well.
Here are some pictures: https://imgur.com/a/zJEsH
As you can see the thread portion (gold) was attached to the socket with two (rivet like) structures. These two structures snapped off and brought the whole thread assembly out of the hood fixture.
I tried putting a couple of different light bulbs into the bare socket to see if the light would work by touching the contact but the bulbs would not work. Have I totally borked the socket? Is there any way for me to fix it? Is there any way for an electrician to fix this?
