I was told the below restricts/governs how much hot water can make it to my tub/shower. I'd like to know what it's called, and how I can adjust it to get hotter water.
I'm attempting to twist the "cap" (the beige-ish color) to the right, but am meeting more resistance than I would have expected (having no knowledge of how it works). I'm afraid to attempt to turn too hard for fear that it is not what I'm supposed to adjust, and I could break/crack the pipe.
Or do I need to find an alan wrench or similar to adjust just the little silver deal at the top?
    I'd call it a "tempering valve" used to stop the outlet water being any higher than a set point. In my country they're mandatory. – Criggie Dec 1 '15 at 23:27
12
Thermostatic Mixing Valve
According to the installation instructions (PDF)
  1. Let the water flow for at least two minutes to allow supply temperature to stabilize.
  2. Calibrate the mixed water outlet temperature by placing a thermometer in the mixed water stream.
  3. To adjust the setting of the valve, loosen locking cap screw with hex wrench, see Figure 4. Cap must be lifted 1/4" to adjust temperature. To increase the temperature, turn counter clockwise. To decrease temperature turn clockwise.
  4. Lower handle and tighten screw.
  5. Check outlet temperature.
