I recently bought a house with a zero clearance fireplace, and had a metal/glass door installed on the front. I suspect the metal door is touching the tiles on the wall above and transferring a lot of heat. When the fireplace is running, I can't hold my hand for more than a few seconds on the bottom of the tiles above the fireplace. However, if I move my hand a few inches up it's just fine. Is this too hot, or expected?
Edit: Here's a picture of the door I had installed. It's made for zero clearance fireplaces. We always have the doors fully open when the fireplace is on. Also, to clarify, this is a gas unit, not wood burning.
